ARP Hardend oil pump drive
Old Aug 9, 2006 | 04:43 PM
Heatmaker's Avatar
Advanced Member
Here's the deal,
when I pulled out the oil pump, I decided to upgrade the pump drive to hardend. So I tapped off the old drive and when my new shaft came in I went to install it. I remember the old one being snug on the internal oil pump gear spindle, but the arp sleave just seams be sitting on the spindle, and the shaft wobbles around. Is this thing supposed to be that loose? Is't it suppossed to sit tight on the rod?
Old Aug 9, 2006 | 06:03 PM
s10er8's Avatar
Re: ARP Hardend oil pump drive
Get one from Moroso, I agree the ARP shaft is crap.
Old Aug 9, 2006 | 07:13 PM
Heatmaker's Avatar
Advanced Member
So.. is this okay, or should I modify it?
Old Aug 9, 2006 | 07:19 PM
s10er8's Avatar
That's the way it's designed so it will be ok.
Old Aug 9, 2006 | 07:27 PM
Heatmaker's Avatar
Advanced Member
That's crap... how much better is the moroso?
Old Aug 9, 2006 | 07:52 PM
s10er8's Avatar
It's the same size down the entire shaft and the sleeve is seperate and held on by a rollpin, I dont especially like the pin but theres probably no way possible for it to go anywhere. The stock shaft is fine except for the plastic sleeve that will eventually crumble from the heat and also the shaft can come out with the distributor and fall in the oilpan.
Old Aug 9, 2006 | 08:38 PM
busta9876's Avatar
never a problem with a Mellings hardened oil pump drive from my local Autozone.
They sit on the oil pump freely too.
Old Aug 9, 2006 | 09:54 PM
Victory Racing's Avatar
Fitting freely is fine, some fit tighter than others.
I use the Melling driveshafts and they always work well for me.
Old Aug 10, 2006 | 06:11 PM
96capricemgr's Avatar
The Melling is half the cost of the ARP, not that the ARP is all that expensive but it is a $6 savings you can put towards some beer or something to calm you down when you start getting frustrated with some silly little part.
Old Aug 10, 2006 | 06:46 PM
streetbad's Avatar
I tried to put mine (ARP) in from the top with the motor in the car and failed. Does this have to go in from the bottom? Or at least with oil pump removed?
Old Aug 10, 2006 | 07:31 PM
Birdman7389's Avatar
Yep, from the bottom, with Oil Pump out.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
