Temp problems after opti install...
Old Aug 9, 2006 | 08:30 PM
95z28man's Avatar
My new opti is in and the car starts up and runs nicely. But I have problem still. I drained the coolant and have a bucket of it sitting out there. However, I went to replace it with new coolant and suddenly the funnel began overflowing?? How can this be when I have much more coolant drained than I put back in? I let it still to see if it went down... it didn't. Then i took a little bit of it out again and started the car again. Drove it for a little with no trouble lights except the "check gauges" light. But anyways, the temp gauge is way up at 260 so I go home. Is this normal after draining the coolant? Do I let it sit and gradually fill more coolant in or something? I'm kinda lost since I haven't done it before.
Thanks for any help.
Old Aug 9, 2006 | 08:52 PM
95z28man's Avatar
Re: Temp problems after opti install...
Ok, I think I just figured it out, if not, I'll post again.
Old Aug 9, 2006 | 08:55 PM
You did not let the thermostat open, so you could put back the rest of the coolant.
Old Aug 9, 2006 | 09:17 PM
95z28man's Avatar
Ok, so I guess I didn't figure it out then. I've been slowly adding coolant to it and starting it up as of now. Do I just remove the thermostat or something to fix it?
Old Aug 9, 2006 | 09:20 PM
95z28man's Avatar
Wait, I just read the thermostat page on your site. Can I open the bleeder screw until coolant comes out?
Old Aug 9, 2006 | 10:36 PM
You should have done that to begin with. Just keep adding until you get it all back in there (or it's full).
HectorM52
Jul 30, 2017 11:46 AM
grabbem88
Mar 18, 2015 01:25 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Injuneer
Dec 15, 2014 09:36 AM
GigaMp3z
Feb 20, 2003 02:57 PM
