52, 58, or monoblade?
Old Aug 9, 2006 | 11:57 AM
Gripenfelter's Avatar
I have an LE2 H/C combo on a 383 with all the bolt ons, hookers, and 3" true duals.
Currently running a 52mm TB because people have told me I might have idle problems with a 58mm because I'm an A4.
Any truth to that? Or should I go 58 or monoblade?
Old Aug 9, 2006 | 12:05 PM
speed_demon24's Avatar
Re: 52, 58, or monoblade?
I think people have problems with monoblades, not 58mm. I just put a 58mm on my car when I put on my ported intake manifold, but I'm not done yet so I can't comment on the idle quality. I think with A4's you need to have the tranny line-pressure reprogramed because get more air in per % of your throttle position though.
Old Aug 9, 2006 | 12:11 PM
Does it make any difference that I have a 93 with a 700R4 and a shift cable in regards to idle quality?
Old Aug 9, 2006 | 12:16 PM
93yellowta's Avatar
I have a 93' with the 58mm holley. I did have to drill a small hole on each throttle blade to get my iac counts down. they were pegged before, now I have them down around 57..seems to idle much better... no other probs. that I am having out of the t.b. seems to be working great.
Old Aug 9, 2006 | 12:34 PM
Any issues with a monoblade?
Wondering how much of a gain I would see going to a 58m or monoblade.
Old Aug 9, 2006 | 12:55 PM
When we had my 381 on an engine dyno, we found the 58mm TB was flowing all the air the engine could use (500 flywheel HP) with the blades only 77% open. The engine could have made the same power with a 52mm TB 100% open. A monoblade would seem to be overkill.
Just a thought.
Old Aug 9, 2006 | 01:53 PM
Thanx Fred. That helps a lot.
sleeperZ96BT
Sep 9, 2015 08:28 AM
MAKQSIK
Parts Wanted
Jun 11, 2015 04:30 PM
fast 93 z
May 5, 2005 08:23 AM
WHYTLIE
Advanced Tech
10
Mar 7, 2005 07:28 AM
