Parts list for fixing a blown headgasket?
Pulling the heads on my friend's '97 Z28 and I was just wondering if anyone can give me a parts list of what exactly we'll need to pull both heads and get it all back together?
Matt
Matt
Re: Parts list for fixing a blown headgasket?
http://www.thunderracing.com/catalog...vid=4&pcid=213
You're also going to need head bolts.
Here's a good write-up, it includes a cam swap that you're not doing, but a good read as to what to expect.
http://afrashteh.com/guide/install.htm
Matt
Matt
Head gaskets, intake gaskets, bolts, coolant, oil.
Change the oil and filter after about 20 minutes of use - this is important so that metal contaminents and the lube that was used doesn’t damage the engine. Change your oil again after a couple hundred miles. After that, it is safe to use synthetic.
allow me to be more specific
That's all fine, but then:
It just always makes me giggle when people do write ups for cam swaps and include statements on how the cam must be "broken in" on an already broken in engine by using regular oil for starters and then after certain said miles are achieved, it being "safe" to use synthetic.
Matt
Matt
Originally Posted by Heatmaker
It'll tell you what, be prepared to replace the coolant line that's in the back of the heads, if you can't get it off.
