can injectors be pressurized with fuel rail off manifold?
Old Aug 4, 2006 | 01:21 PM
35thssLs1's Avatar
ive been fighting a random misfire for about 6 months now, and ive narrowed it to a lean condition on the passenger bank (manifold glowing, new cats), can i run the fuel pump with the fuel rail off the manifold to see if i have a leaky injector(s) or are the clips not strong enough to hold them on with 41 psi fuel pressure
Old Aug 4, 2006 | 01:32 PM
Z28SORR's Avatar
Re: can injectors be pressurized with fuel rail off manifold?
Don't know why not? Am a little confused though. Why would a leaking injector cause a LEAN burn. Are you sure you don't have an EGR or other vacuum problem?
Old Aug 4, 2006 | 01:36 PM
35thssLs1's Avatar
i forgot to mention the engine has to crank for several seconds on startup hot or cold and when i connect the fuel pressure gauge it makes 40 psi but with key off it loses pressure quickly, im tryin condemn either fuel pump check valve or injectors (fuel pressure regulator is 3 days old), so im thinking if the injectors are worn enough to leak then they may be ****ed up enough not be opening all the way
Old Aug 4, 2006 | 02:04 PM
35thssLs1's Avatar
egr valve is brand new too
Old Aug 4, 2006 | 02:37 PM
OBE1 95Z28's Avatar
Yes you can check the injectors by just pulling the fuel rail off the intake manifold. Blow off the intake around the injector holes so as not to drop dirt in the holes with the fuel rail off. Also put a light coating of motor oil on the injector o-rings when reinstalling the fuel rail.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
