Changing O2 Sensors
Old Aug 2, 2003 | 09:58 AM
Stormman's Avatar
Question Changing O2 Sensors
The mechanic wants $250 installed for both o2 sensors.
I figure I can get them for $25-$30 ea form Dal or Jason.
So my question is are they accessible from up top, easy to get to, and where exactly are they? If I can see them & get them out I will definately do them my-self.
Thanks again
Old Aug 2, 2003 | 10:16 AM
revtime's Avatar
The one in the Y-pipe is not too bad but the one in the manifold can be a PITA its hard to get too and usually welded in. You can change them yourself but you may need a torch to get the passeger one out. Try it yourself cause you might get lucky and they come out real easy.
I would definately try it myself before paying 250 bucks.
Old Aug 2, 2003 | 11:26 AM
LT1ponykilla's Avatar
Where are you getting 02's for $30? Can someone please let me know?
Old Aug 2, 2003 | 12:00 PM
JSK333's Avatar
The driver's side is SUPER easy. The passenger side is definitely harder, but not impossible. I got it from beneath w/o removing anything, but I have skinny arms.
You can get them for around $33 from Jason Cromer (GM parts seller, do a search here).
Old Aug 2, 2003 | 01:15 PM
96 WS6's Avatar
i got mine from www.rockauto.com for around 30 bucks.
Old Aug 2, 2003 | 01:17 PM
Rich_z28's Avatar
Dal Slabaugh: 1-800-362-9494 ext 501
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
Jason Cromer: 1-877-726-8295
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
Old Aug 2, 2003 | 04:09 PM
Stormman's Avatar
[QUOTE]Originally posted by JSK333
[B]The driver's side is SUPER easy. The passenger side is definitely harder, but not impossible. I got it from beneath w/o removing anything, but I have skinny arms.
Are they directly in the manifolds?
Anybody got a pic or one of those parts diagrams like the dealers have?
Thanks again
Old Aug 2, 2003 | 04:16 PM
Compstall's Avatar
I JUST did mine a couple days ago. The driver's side is mounted into the y-pipe. The passenger's side is mounted into the manifold.
I have a Borla y-pipe, so access to the passenger side is impossible without removing something. I pulled my starter out and it was right there. The driver's side was easy since I've had it out several times in the recent past, but the passenger side was a B#$%^. I soaked it down with WD40 first but it was still jammed in there.
Go buy yourself a 22mm wrench at a parts store. Makes it much easier. Just as I was about to let the CAR win the battle on the passenger side it popped loose like it was nothing...
I ordered my O2's from Carparts.com for 30-something each. You want the AC Delco part #AFS-75 sensors.
Old Aug 2, 2003 | 05:37 PM
JSK333's Avatar
Oh yeah, I should mention that if you're replacing the original ones, you may have a tough time getting them loose.
I had to take the car to an exhaust shop for the passenger side--they said it barely came loose even with a breaker bar!
I was speaking access-wise in terms of ease/hardship.
After cleaning them recently, they were pretty easy to get out (make sure you put some anti-seize on them, it'll help for next time).
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
captcorvette
Mar 7, 2015 12:37 PM
eazyZ
Mar 1, 2015 07:12 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 8, 2002 12:36 AM
