valve cover leaks
Old Jul 31, 2003 | 08:17 PM
rage366's Avatar
valve cover leaks
both of my valve covers are leaking oil, and i find this rather puzzling because the gaskets are maybe 4 months old.
could this just be bad luck, or is something causing the gaskets to go bad prematurely?
any suggestions on what i should check?
Old Jul 31, 2003 | 08:43 PM
funina91ss's Avatar
make sure they are tight,or over tightened.
Old Jul 31, 2003 | 08:52 PM
Zerosheaven's Avatar
make sure you rebolt them in a cris cross pattern. happend to me once and that was the problem.
Old Jul 31, 2003 | 08:59 PM
PatriotTA's Avatar
Yeah, make sure you torque them to the spec and use the proper pattern, as was said. And make sure you have enough RTV on there, as well as do a good job cleaning the surfaces before you seal them (use brake cleaner or acetone). Also, the stock valve covers aren't that great. You could go with an aftermarket aluminum valve cover and that won't leak.
Old Jul 31, 2003 | 09:32 PM
How do you criss-cross bolts that are in a straight line?
Old Jul 31, 2003 | 09:34 PM
96z's Avatar
96z
Also make sure the gasket didnt shift or tear when you were installing it. That happened to me once a couple years ago. Its hard to see in the rear of the motor sometimes...
funina91ss's Avatar
I think he ment stagger them
Old Jul 31, 2003 | 09:41 PM
That might make more sense.
Old Aug 1, 2003 | 04:00 PM
whats stagger them??? thats probbly what i meant but i just want to make sure
Old Aug 1, 2003 | 05:17 PM
rage366's Avatar
wiggle them on from right to left?
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
ModdedNerd
Jan 29, 2015 07:23 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
