I have a rough idle and...
Old Aug 1, 2003 | 04:54 PM
yorkie's Avatar
it has started with hard starting, last time it did this it took 6 tries to start it and the pedal pushed to the floor while cranking it to start it, checked the fuel pressure and it is ok and the leak down is from 42 to 32 in ten minutes. Pings sometimes too, not all the time. Ideas????
Old Aug 1, 2003 | 06:46 PM
yorkie's Avatar
also studders sometimes and especially...
off idle, cruising down the road the car runs fine.
Old Aug 1, 2003 | 10:35 PM
$hawn's Avatar
32psi seems kinda low, really low if thats with the vacumm line off, sounds like either the fuel pump, fuel pressure regulator, or injector(s) are leaking.
Old Aug 1, 2003 | 10:41 PM
yorkie's Avatar
It was with the line connected (vac one)
has new injectors and a new adj. fuel regulator.
Old Aug 1, 2003 | 10:47 PM
yorkie's Avatar
this was by turning the key on and..
letting it prime, then turning it off and let it sit for 10 minutes.
Old Aug 1, 2003 | 10:59 PM
$hawn's Avatar
Mine would be at 42 while it was priming, and after it was done(also running it would bounce between 38-39), so 32 sounds a tad low, i'm not sure how long it's supposed to hold pressure, but should hold little longer than 10mins. though, could be your pump then.
Boss002
Jan 20, 2016 12:17 PM
michaelzilinski
Jul 31, 2015 08:41 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
Noct
Jul 14, 2015 01:18 AM
