Wiring Up Air/Fuel ratio gauge
Old Aug 1, 2003 | 03:37 PM
ny_z28man's Avatar
Question to those who have wired up an Air/Fuel ratio gauge. Where did you run the wire too??? I'm thinking you could splice into one of the wires on the back of the PCM But I dont know which color(s) to use. I want to wire it in so I can select between the front O2 and the rear O2. Just dont know where to hook it up. Could someone please help....
Old Aug 1, 2003 | 04:04 PM
BigEvil's Avatar
Splice it into the violet wire coming from your front O2 sensor.
Old Aug 1, 2003 | 04:12 PM
The terminals for the front O2 sensor signal wires are C20 purple/white (Bank 1) and C8 purple (Bank 2). Connector "C" is the gray or clear connector. You can use a single pole, double throw switch to allow you to read either side.
Just curious.... why would you want to read the rear O2 sensor?
Old Aug 1, 2003 | 05:09 PM
KWKSLVR's Avatar
S.E. Region Moderator
I think he might mean the left front o2 and the right front o2???
Old Aug 4, 2003 | 12:22 AM
ny_z28man's Avatar
Sorry I did type that up wrong, I ment to say Right front O2 and Left front O2. I found a purple/white coming out of the terminal labeled red or blue I forgot which one it was. How can I find what purple to use? I counted 3 or 4 of them. Just one more thing. Where can I get a nicely layed out diagram labeling all the wires running into the PCM? Just FYO my PCM is an OBD2, Thanks again,
-Paul
Old Aug 4, 2003 | 12:30 AM
Dave19yz28's Avatar
PCM pinout
I did mine to the Clear/gray plug...#8
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
97ss1826
Mar 13, 2003 11:58 AM
Rich_z28
Aug 29, 2002 10:44 PM
Burn_Out
Aug 18, 2002 08:49 AM
