Rear main seal
Old Aug 1, 2003 | 11:25 AM
Rodrigues's Avatar
Rear main seal
I got the old seal out and removed the 4 bolts, but the ring that the 4 bolts hold wouldnt come out. I ended up just replacing the seal on it... Is it okay to just keep that old semi circle gasket and re tighten the bolts?
Old Aug 1, 2003 | 11:59 AM
thewinner's Avatar
thats cause its held in place by the oil pan the back 2 studs that hold the oil pan on go into that ring
Old Aug 1, 2003 | 12:48 PM
95 Z/28 LT1's Avatar
Super Moderator
You don't want to take off the seal holder. Just pull the old seal out and tap a new one back in and you're done.
Old Aug 1, 2003 | 01:11 PM
scoobysnax83's Avatar
yep you went to far....
Old Aug 1, 2003 | 01:14 PM
Rodrigues's Avatar
Since it never actually came off I can just screw those 4 bolts in and it wont leak right? Im changing the oil pan gasket as well...
Old Aug 1, 2003 | 04:02 PM
You should be good to go.
Old Aug 1, 2003 | 04:24 PM
Super Moderator
The oil-pan gasket kit should come with a gasket that is for the aluminum piece, so you can change it if you take the pan off.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
BigWil
Mar 29, 2015 12:24 PM
carl.froehlich
Mar 13, 2015 12:38 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
