normal oil pressure
normal oil pressure
i have a 95 m6 t/a
i just changed my air filter (paper one) and fuel filter.
afterwords i noticed that my oil pressure was a little high (have no idea if there is any relevence)
anyhow the oil pressure under idle is usualy about 40-60 (
and under throttle it will usualy hit 60-70
is there something wrong with this or is this normal
( i thought it was kinda good coz atleast it meens i dont have any major oil leeks
is there anyway to fix this i.e. a breather?
)is there anyway to fix this i.e. a breather?
how could the cam affect pressure at WOT? the only factor is rpm is'nt it which determines pressure increase(not including the motor it self i mean, and how much it is worn) i can see it affecting pressure at idle, since it would be low and sparatic and vary easiy...?
Also, are you guys talking about oil pressure while cold, cuz mines always 58-64 cold, and even better WOT, but hot, its about 22-24 idle...so since you say it was right after you changed this stuff, so it had at least a 1/2 hour to cool, so i assume this is cold pressure which is normal for sure, so you have nothing to worry about, but that pressure is good even for cold, so congrats...how many miles?
well today i went driving for half an hour and the pressure actualy hit about 75, sometimes im realy panaoind and am always lookin at the guage, it seems to actualy increase when hot. im using mobil drive clean 10w30
also
why are you guys envouis of the oil pressure??? why would yours be low?? gasket leak or oil pump or something???
my car has about 83k miles
also
also
also
Everyone else's aren't "low", they are just lower than yours (which is more typical). Gasket leaks don't cause low oil pressure.
Originally posted by shoebox
[BEveryone else's aren't "low", they are just lower than yours (which is more typical). [/B]
