SLP Take-out Posi Install?
I'll be installing an SLP takeout posi (from '99+ f-bodies) into a friends LT1 4th gen. His car has the stock auburn (?). Any tips/tricks to installing this posi? I've heard that the only thing that really needs to be done is to check the backlash. Is this right? How do we go about doing this for this particular case?
just put one in last weekend!!
I also installed Richmond 4.10 gears.
If you are using the same gears the backlash will probly be out.
mine was at .007 stock and .016 after (with new gears).
If it is out try and use original shims (one piece) not a build up of different sizes. Luckly a mechanic I know had a box of them to chose from. Thanks Al. Use synthetic 75w90 gear lube and limited slip additive and go have fun.
Good luck
RYAN
Good luck
RYAN
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Richardan15
May 30, 2015 08:36 AM
