Got $700 to spend go with converter or LT's???
Old Aug 1, 2003 | 01:29 PM
Jay-Roll's Avatar
I have some extra cash to put into the car. I would be getting a vigilante if I got a converter and getting Hooker LT's if I got headers. Since the price is about the same I would like some opinions as to which route to take first. I know I'm gonna be spending a litte extra to get a shift kit and tranny cooler when I go with the converter. Also I know I need a Y pipe to go with the headers. So I've factored in that extra cash to be available a week or two after the original purchase. I just don't know which mod to get first. Help me out guys.
Jason
Old Aug 1, 2003 | 01:35 PM
FacelessZ's Avatar
You can get Jet-Hot coated LT's shipped to your door for $493...they're the exact same layout as the Hooker LT, only Jet-Hot LT's are thicker gauged...
As for the stall, you can usually find a great deal on them unless you want to drop the $700 for a new one...I got mine used with a few hundred miles on it for $350...
Old Aug 1, 2003 | 02:40 PM
GREGG 97Z's Avatar
To take better advantage of a higher stall you would probably want to get better gears to go with it as well. I would get the LT's first. A higher stall isn't going to gain you any hp, the LT's certainly will
Old Aug 1, 2003 | 03:12 PM
KCFormula's Avatar
Stall+trans brake+sticky tires=
Nothing else like it IMO.
As a side note I have a buddy with 2.73s that did longtubes before a stall or gears and he ran pretty much the same 1/4. And another friend of ours did a stall and gained .5 sec off 1/4.
Old Aug 1, 2003 | 03:19 PM
Spinner's Avatar
I'm guessing the trans brake is the hand brake (parking brake) but what does it do for you in racing?
Old Aug 1, 2003 | 03:31 PM
Kain's Avatar
Nope, its not a brake of that sort. It basically holds the transmission between reverse and drive to keep the car in place while you raise the rpms to what you want them to (even pass the stall rating of the torque converter). Then when you go to launch, you just release the trans brake and you launch like no tomarrow if you've got the traction.
I'm 99% sure you can't put one on a 4L60E, and the only tranny's I'd put it on would be a TH400 and Powerglide, I've heard they don't do so well on a TH350.
Back on topic: I'd get the headers before the stall, because with the stall, you'd need sticky tires to fully take advantage of them.
Old Aug 1, 2003 | 04:08 PM
FireAm94's Avatar
When I had my auto the converter helped it out tremendously...but I had the little hotcam too. I would probably go with headers and gears if it was me......stall when ur getting closer to a cam.
Old Aug 1, 2003 | 04:46 PM
Antz97ZNJ's Avatar
id get headers and get rid of those 273's next
Old Aug 1, 2003 | 05:25 PM
kyzer soze's Avatar
Jet hot lt headers and gears. a little over $700
Old Aug 1, 2003 | 06:09 PM
Black_Z28's Avatar
I would get the Lts.
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
