96 LT1 will not start on hot days.
I had my engine rebuilt at the end of last year because I blew the heads out. And on several occasions after driving during a hot day, I turn the car off and it will not restart. The car will turn on for a few seconds but I can't get any gas to the engine. After the car cools down it start up and run without problems. I've taken in to have the mechanic run a diag but they find nothing. Have anyone had this problem?? Since I had the engine rebuilt I installed a performance K&N airflow kit. Could this be part of the problem?? If so what can I do fix this and start enjoy the feeling of driving my Z again without any issues.
Thanks,
Shanez1@hotmail.com
Thanks,
Shanez1@hotmail.com
If you're sure its a fuel problem then you should swap out the fuel pump. Verify this by attaching a fuel pressure guage to the schraeder valve. If the fuel psi comes up slowly then its your pump.
Otherwise it could also be your coil.
I though of heat soak right away; but, the car cranks, starts then dies when it is hot is what I gather from your post?
Things to look at:
air filter dirty
bad engine ground somewhere
fuel not reaching injectors
loose ignition system connection
Good luck
Things to look at:
air filter dirty
Good luck
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
