Normal RPM at idal
Old Aug 1, 2003 | 12:27 PM
cjksflorida's Avatar
Normal RPM at idal
What is the normal RPM for an M6 at Idal, Mine runs right at 1000RPM and I think it's high, maybe not though. Thanks for any input
Old Aug 1, 2003 | 12:33 PM
z28marine's Avatar
mine is around 580-900
Old Aug 1, 2003 | 12:39 PM
BUBBA's Avatar
If you are going by your tach (which reads 200-300 high) you are probably spinning around 700-800.
My idle is set for around 900.
Idle RPM shouldn't be a concern unless it is running faster than needed to keep the car from stalling out.JMHO
Old Aug 1, 2003 | 12:53 PM
Thanks,
To be honest my stock tach and aftermarket tach are pretty much the same at idle. It's not really a problem I was just wondering what the norm was for our cars.
Old Aug 1, 2003 | 01:12 PM
got_hp?'s Avatar
after installing longtubes, pcm, new wires etc etc , now my car idles at 550-600 rpm (after its warmed up).............its probably just barely above stalling............i do have a slight exhaust leak at the collectors (i think the header gaskets are ok).
is this low idle bad?
it never stalls tho............yesterday i idled for 45-60mins at the airport with my AC on max (1/4 tank of gas, thanks airport security).
Old Aug 1, 2003 | 04:19 PM
The value programmed into the stock PCM for the M6 is 800rpm. It should stabilize there fully warmed up (+/-25rpm).
Old Aug 1, 2003 | 09:59 PM
got_hp?'s Avatar
what are the most common causes for a low idle.......since mine is about 550.............i have a slight exhaust leak at my collector gasket.........but i think the header gaskets are very tight.
would a leak in my intake manifold create a low idle?
Old Aug 3, 2003 | 11:37 PM
No... vacuum leak will cause high idle. Most common cause of low idle would be a dirty IAC valve, or the idle air passages in the base of the throttle body are crudded up.
Old Aug 3, 2003 | 11:49 PM
Z28ROC's Avatar
got_hp?, Do you have a manual or auto?
Old Aug 4, 2003 | 08:18 AM
got_hp?'s Avatar
manual
Old Aug 4, 2003 | 08:27 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
stock idles:
m6: 800
a4: 550
the tach is off about 200rpms tho...
my friends z idles at 1500....
beltrunner
May 17, 2015 10:18 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
94Form
Feb 10, 2015 11:23 PM
edman
Jan 25, 2015 02:41 PM
edman
Jan 22, 2015 02:45 PM
