Reinstalling clutch fork
Old Jul 31, 2003 | 02:51 PM
NVetro's Avatar
When i removed my trans, i saw thje clutch fork was on the throwout berring, i unbolted the bolt that held it to the trans. I just bolted it back on so i can be ready to put the trans back in. One problem, there is ALOT of play up and down and side to side with this clutch fork. Is this normal? Will the play go away when i click this thing on the throwout berring?
Old Jul 31, 2003 | 02:53 PM
Make sure you have the spring clip on the fork OFF the ball. The fork should be real loose and floppy. After you get the tranny bolted up, you put the "C" end of the fork over the T/O bearing, and push it in hard, seating the spring clip on the ball, and the "C" in the bearing. It won't move around at all.
Old Jul 31, 2003 | 02:56 PM
NVetro's Avatar
What spring clip, is it ont he fork or the trans? I understand the C part of the frork locks with the throwout berring, but what is the spring clip your talking about? I thought the fork was one solid peice.
Old Jul 31, 2003 | 03:04 PM
Go take a look at the fork. It has a long slot in the middle that allows it to be pulled back, off the bearing, and off the ball on the tranny. In the slot, ON THE FORK, there is a bent metal spring that snaps down on the ball when you push the fork in, and holds the fork on the ball, keeps it from falling off the bearing. The "C" doesn't "hold" anything.
I'm sure I've shown you this photo before.
Old Jul 31, 2003 | 03:52 PM
NVetro's Avatar
ok i went to look at the fork, and i saw the clip your talking about. Its right around the bolt that bolts tot he trans, I dont see how this acts with the trowout berring though, does the brring actualy sit in the C portion of the fork? I am confused, have another diagram?
Old Jul 31, 2003 | 04:38 PM
importeater's Avatar
Originally posted by NVetro
does the bearing actualy sit in the C portion of the fork?
Yes.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
