Anyone ever modify the Ypipe where it connects to th eheader?
Old Aug 1, 2003 | 01:03 PM
superkia8's Avatar
Im trying to find out if anyone has ever modified the ypipe where it connects to the header on the passenger side? I have a 96 with MACs and the passenger side will not stay tight. I had read somewhere of someone making 3 small cuts into the ypipe where it connects so that it would expand a little more and take in the header better???? Has anyone ever even had this same problem and has anyone ever did any modifying to fix this? Any help would be appreciated because I have to tighten this thing about once a month
Thanks,
Rich
Old Aug 1, 2003 | 01:23 PM
grygst76's Avatar
Re: Anyone ever modify the Ypipe where it connects to th eheader?
Originally posted by superkia8
Im trying to find out if anyone has ever modified the ypipe where it connects to the header on the passenger side? I have a 96 with MACs and the passenger side will not stay tight. I had read somewhere of someone making 3 small cuts into the ypipe where it connects so that it would expand a little more and take in the header better???? Has anyone ever even had this same problem and has anyone ever did any modifying to fix this? Any help would be appreciated because I have to tighten this thing about once a month hardware stores sell "locking" washers that you use to keep it tight, it's the only way I kept mine tight aside from cutting. Does your passenger cat bang on the conrtrol arm? did you use stock cats or the replacement from MAC??
Thanks,
Rich
Old Aug 1, 2003 | 04:57 PM
superkia8's Avatar
grygst, did i miss something? LOL!
Old Aug 1, 2003 | 06:37 PM
grygst76's Avatar
I'm sorry man I was at work!! Yes mine bangs like crazy too. The only thing I've done is try and keep it tight against the arm; but tomorrow I'm going to cut the "lip" of the control arm off in hopes of eliminating the banging!! IT drives me absolutley crazy from 1600 rpms until 2200 when it stops banging. It's hard to eliminate because when it's cold it's worse and when it's hot it doesn't do it. On monday I am contacting MAC and find out in more depth what the problem is!!
Old Aug 6, 2003 | 11:12 AM
grygst76's Avatar
This is what I did this weekend; I loosened all the bolts to the drivers pipe. I then dropped it down to be flush with the control arm. I then used some solid washers and some red loctite and bolted everything down real tight. The problem has been solved!! It was a real pain to get it all lined up as well but the finished product no longer bothers me!!
Old Aug 6, 2003 | 06:40 PM
superkia8's Avatar
Hey grygst, I do appreciate you letting me know your progress but we had different problems. My problem was that where the ypipe connects to the header, it keeps coming loose. But again I appreciate the help.
Thanks,
Rich
Old Aug 6, 2003 | 06:52 PM
grygst76's Avatar
I used red loctite on the screw and then tightened it as much as I could and did the same for the side that mates to the passenger cat and it stopped it from loosining..
Old Aug 6, 2003 | 07:18 PM
superkia8's Avatar
Hey man, thats sweet! I didnt even think that you had the problem and you still came through for me
Anyways, thanks again!
Nayr
Mar 3, 2023 08:34 PM
marlar98
Sep 12, 2018 07:18 AM
Jeff1904
Jun 5, 2016 05:00 PM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
