What size injectors?
What size are the stock injectors on a 95 Z28?? I have added slp y-pipe, cat removed, flowmaster, 3.73 gears, ported mass air, k&n fipk, 150 shot NOS brand dry kit, madZ28 programmed computer. Underdrive pulleys. What size injectors should i go with to accomodate the dry kit and added mods? And what are some good brands and places to get them for descent prices?
I believe stock 95 z28s came with 24lb/hr injectors. You might want to upgrade to 30lb/hr ones instead. I don't really know where to get them from though, actually I am looking for 30#s myself. Good luck.
If your "NOS dry kit" is the 5176, you want to stay with the 24# injectors, with your otherwise limited mods. The 5176 kit raises the fuel pressure to 85-90psi when you spray, to get the added fuel. You don't need a bigger injector. The NOS jetting recommendations are based on the stock 24's. What you should consider with the dry kit is changing you 24# stock injectors out for 24# pintle style (SVO, Ford, Bosch, etc.) injectors. The stock ball and seat injectors do not like to operate at 90psi, and can lock up on you.
