qucik fan mod question
Old Jul 31, 2003 | 10:32 PM
clownhair's Avatar
quick fan mod question
i am rewiring my switch to stop the dtc. I could not find 1 watt 47 ohm resistors but I did buy 1/2 watt. will this be fine or do I need the 1 watt? Also do the diodes have any specific way they should be pointing?
Old Jul 31, 2003 | 11:01 PM
clownhair's Avatar
anybody?
Old Jul 31, 2003 | 11:03 PM
jasons93z's Avatar
are you using LED's? If you are, radio shack has LED's with 1 watt resistors in them.
Old Jul 31, 2003 | 11:13 PM
ZYALATER's Avatar
I used 1/2 watt resistors and it's working fine for me.
Old Jul 31, 2003 | 11:23 PM
clownhair's Avatar
sweet thats what i needed to know. how about the Diodes though?
Old Jul 31, 2003 | 11:45 PM
MentalCaseOne's Avatar
If you refer to the Fan Mod with a toggle switch and the LEDS
Heere is how your do it if you wanna know.
** Typical LED's.... 2v and 20 milliamps working values.
** Typical voltage with engine runing is 13.8volts
13.8volts voltage minus 2 volts absorbed by the LED equals
11.8V this is the voltage that will run across the resistor.
**Now we calculate the resistor... R = V/I
where R= resistance
V= voltage across resistor
I= amps across the resistor
R = (11.8/0.020) or 550 Ohms
**Now we calculate power consumption
Watts = (Volts X amps) across your 550 Ohms resistor
W= (11.8 x .020) or 0.236 Watts
** A 1/4 Watt resistor (0.250 watt) or more will do just fine.
**if you curios about how much power is being used by the LED
then use the voltage across the LED times the Milliamps
passing through it.
or ( 2v x 0.20) equals ( 0.04 Watt)
you can use the same method if your LED has diff values.
I hope this helps to understand it .... oh and yes the LEDs are
polarized.... one lead to the positive the other to ground.
Oh if you dont find the exact resistor value get the closest one
with a higher Ohms value you can find... anything up to 700ohms can work just fine...
Marvin
Old Aug 1, 2003 | 09:15 AM
clownhair's Avatar
thanks marvin. Very informative
Old Aug 2, 2003 | 06:09 PM
Dang Dang Dang dude... I did all the calculations for your status Leds...
I just realized you were refering to the Resistors to keep the PCM from throwing codes... My bad... sorry
I dunno how the PCM reads the fans so I cant predict if the resistors mentioned by the other memebers will work or not..
Sorry..for the confussion
Marvin
Old Aug 3, 2003 | 06:27 AM
clownhair's Avatar
no problem. I installed them and there not throwing a code so everything is good.
linz
3rd Gen / L98 Engine Tech
Apr 7, 2015 11:49 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Feb 1, 2015 08:26 AM
cmdeshon
Dec 27, 2014 10:06 AM
