what else is needed for a cc305??
I want to get a CC305 and i am pretty sure i need more than just the cam to install....
if i need to get them, specificly what lifters and valve springs do i need to get and what else do i need?
stock replacement lifters (gm, speedpro, etc.) theyre all the same. you could just keep the ones you have if you want though. theres also the comp r lifters, which are pricier , but i dont see why youd really "need" those. youll definitely need better valvesprings, the "double " type (sorry, dont know specifics about em
). a set of roller rockers would be beneficial as well. and a pcm tune, for sure. if you think you need to upgrade your injectors (which i dont think you do), you could do that too. could also get a new timing chain, stock replacement, lt4, lt4 hd, double roller, all depends. (if you do get a new chain, make sure to replace the sprockets as well
). youll also need gaskets (timing cover, intake manifold, etc.) just a few ideas
hth
hth
