Cracked rod... new radiator needed?
Old Aug 1, 2003 | 10:05 PM
madwolf's Avatar
Arrow Cracked rod... new radiator needed?
Someone mentioned that when internal engine damage occurs, some shavings might get stuck in the radiator, then later on (after a new engine is in) they might circulate with the oil and cause damage.... since I've never heard of this, how does one prevent such thing? Is a radiator replacement necessary?
Thanks.
Old Aug 1, 2003 | 10:16 PM
HardcoreRM125's Avatar
I dont think its really possible inless your antifreeze is mixing with your oil anyways and in that case , your already ****ed ...
However i HAVE heard that if you have an Oil Cooler, and you blow up your engine , that CAN happen if you dont have it flushed out as well as any lines or fittings for the oil cooler
calaban
May 18, 2020 06:43 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
