valves why no 2.02 int 1.60 ext???????????
Old Jul 31, 2003 | 06:48 PM
amean94ta's Avatar
everyone i see on here has 2.00 int 1.55 ext or lower
Old Jul 31, 2003 | 08:08 PM
amean94ta's Avatar
ttt
Old Jul 31, 2003 | 09:53 PM
NightTrain66's Avatar
if you machine the stock seats in an LT1 head as large as they will go, a 2.00/1.56 will fit perfect and be sealing at the edge of the valve. When you use a 2.02/1.60 valve, you are placing it in the same seat so you are basically placing a slightly larger valve in front of the sae size hole. The 2.02/1.60's are not realy hurting any CFM but DEFINITELY not gaining any.
You can use 2.02/1.60's but the valve is sealing a little more on the back side of the valve. I have used 2.02/1.60's and 2.00/1.56's and never noticed a noticable diff in flow#'s or HP #'s. You do not have to worry about any seats falling out or things like that happening.
If you are gonna buy new valves any way, you might as well get the 2.00/1.56's but if you already have the 2.02/1.60's I would use them.
You are a little more limited on back cut's on the valve but that is the main difference.
Phil (Skarodom) made a comment on this a few days back. He said basically the same thing.
NightTrain66@msn.com
Old Jul 31, 2003 | 10:23 PM
Gripenfelter's Avatar
I have 2.02 int 1.515 ext.
I just made 478hp and 490 lb ft on the dyno (at the motor)
Old Aug 1, 2003 | 08:35 AM
Perry93TransAm's Avatar
If youre using the stock size Chamber the 2.02s will actually hurt your low lift flow #s , but if you have a quick opening cam then you wont notice anything. If you pocket port the bowl to around 85% of the valve face area then put a good valvejob with it along with some unshrouding in the chamber youll notice more than just having the Valvejob done. I like the 30 deg top cut on a valvejob than the 45 deg. Nice #s grip , what cam are you using.
Old Aug 1, 2003 | 01:23 PM
Mindgame's Avatar
Oh my...... read through this thread
http://web.camaross.com/forums/showt...ght=valve+size
I think alot of people are mis-quoting what they've read.
-Mindgame
Slayer
Aug 17, 2015 03:55 PM
96SilverRam
Aug 9, 2015 04:15 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
