Please help to get my new motor w/cc305 etc to run right.
Old Aug 1, 2003 | 01:50 PM
Shawn W's Avatar
Ok so i go to the shop to drive my car for the first time today. The new engine was just finished being installed. First let me start with my mods:
New 355
Eagle Crank
Scat 4340 Rods
Speed pro .030 over pistons
CC305 cam
Crane Valve springs
Crane Roller lifter
Crane Gold non-SA roller rockers
Comp Hardend pushrods
Comp Hardned guidplates
Lunatti double roller timming set
MAC headers/ Y pipe
New plugs and wires
Here is the problem. The car starts up and idles good (loopey)
When i am drivning up to about 2400 RPM the car is a dog. Makes Poping noise back through the intake and just don't have any power. After it reaches 2500-2700 RPM's it goes. It seems to me like it is running really rich. Smells rich and the poping through the intake.
I did notice that the Fuel Pressure Regulator is kinda smashed a little bit. The cylinder part has about a 1/4" deep gash in it.
Do you think this could be it?
I was under the impression i wouldn't need a stall with this cam am i wrong?
Also this is on stock tunning. I plan to get the PCMFORLESS and put it in. I don't think it will fix my problems though. I think there is either a vaccum leak somewhere, maybe a electrical sensor( no SES light though) Once it hits about 2500 RPM it instantly clears up and runs fine.
What do you guys think?
Shawn
Old Aug 1, 2003 | 02:02 PM
FastGuyJR's Avatar
Check for vacuum with a vacuum gauge. Check your fuel pressure with a fuel pressure gauge. FP should read ~43.5 psi with the vacuum removed from the regulator.
JR
Old Aug 2, 2003 | 01:46 PM
Shawn W's Avatar
ttt still looking for answers.
Shawn
Old Aug 4, 2003 | 12:14 AM
Shawn W's Avatar
and what should my vaccum be at idle and 2000 RPM's?
Shawn
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
jb4xx
Feb 2, 2015 10:00 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 5, 2015 07:14 PM
