Cleaned my MAF, did I do it right?
Old Oct 10, 2003 | 06:50 AM
X-Jester's Avatar
Hello all,
I put a K&N FIPK on about 5000 miles ago, and in keeping with what the K&N manual and the posts on here read, I took my MAF off to clean it. The manual states something to the effect of an oiled filter making your MAF screen & sensors dirty.
Anyway, here's what I did. I took the MAF off and let it cool down, then took a large can of carb/choke cleaner and sprayed a few parts. The screen came clean, but the inside of the MAF ends were still horribly dirty, as were the MAF sensors themselves. I took the MAF ends off, set the sensor aside, and sprayed/toothbrushed/wiped clean the MAF ends. Next, I took the plastic sensor housing and very lightly sprayed the sensor elements until I saw silver again. <-- This is the part I'm concerned about. I've heard the only real problem with cleaning the MAF is if you TOUCH the elements with something, spraying them while cool won't do much. The car idles better, has a better throttle response, and I *think* it's pulling a bit harder down low, but that might just be in my head.
Anyway, the car runs perfect now, and as long as I didn't do anything too dangerous, I'd recommend any of you with FIPK's and a slight hesitation down low and/or a rough idle give this a try. It worked for me, and as far as I know, this is the original MAF, which means it's 9 years old with 100k miles on it, and it took a cleaning very well.
Thanks for your time, please respond with your thoughts.
Old Oct 10, 2003 | 07:02 AM
IXLR894Z28's Avatar
I've been thinking of doing this also (same year as yours), How long did it take?
Old Oct 10, 2003 | 07:26 AM
X-Jester's Avatar
Total time was about an hour. As soon as I got home I pulled the MAF (it was still pretty hot, keep a towel handy if you have a low pain threshold).. I let it sit for about 15 minutes, it cooled off okay. Took about 15 minutes to remove the MAF ends, clean everything, and put the MAF back together. Then I let it air-dry for about 30 minutes. I picked it up every 2 or 3 minutes and blew as hard as I could through it to help dry it off. So yeah, total turnaround was about an hour for it, and I'd say it was worth it.
Old Oct 10, 2003 | 07:31 AM
IXLR894Z28's Avatar
Looks like I have a weekend project now, thanx!
Old Oct 10, 2003 | 08:22 AM
b-stevens's Avatar
I sure hope it doesnt take a full weekend for you... it took me about 15 to 20 minutes to get it done... i had to use q-tips
Old Oct 10, 2003 | 08:34 AM
Josh-'04 GTO's Avatar
Carb and choke cleaner is not the first choice. Electrical contact cleaner is since it dries 100% clean and residue free.
Old Oct 10, 2003 | 08:42 AM
IXLR894Z28's Avatar
I meant a project for the weekend, let's hope it doesn't take me all weekend, or I've probably really screwed things up. As for the electrical cleaner, Radio Shack and stores like that?
Old Oct 10, 2003 | 09:01 AM
X-Jester's Avatar
Next time I do it I'll use contact cleaner - I sure hope I didn't do any damage. I think I'd know by now, but I'll definitely use contacft cleaner next time.
Old Oct 10, 2003 | 10:29 AM
Red96Lt1's Avatar
Thanks for the tip, I have been thinking about doing that and now I definitly will!
Old Oct 10, 2003 | 11:38 AM
JSK333's Avatar
I was one of the, if not the, first ones to use the contact cleaner on the MAF sensor several years ago.
I recently found it will not take off as much residue as a Q-tip with rubbing alcohol will. It's a night and day difference comparing what the filaments look like afterward.
And yes, I do suggest doing this. Make sure you get both sides of the filaments!
Old Oct 10, 2003 | 02:46 PM
b-stevens's Avatar
If your going to use electrical contact cleaner, last time i checked the radioshack by me just carried the stuff with lubricant. Dont use this, Most auto stores should carry it without.
Old Oct 10, 2003 | 02:53 PM
Terran2k's Avatar
yeah i have heard people done it with carb cleaner, q-tips, and electric contact cleaner (without lubricant) all seems good, as long as you dont damage the sensors.
Old Oct 10, 2003 | 03:59 PM
96 WS6's Avatar
Doesn't take more than 5 minutes. Take it out, clean the resistors with rubbing alky and q tips. Wipe down the inside and if you want spray the screen. Let it air dry (I put it infront of my fan for a couple minutes). 30 minutes of drying is not necessary... electrical cleaner and rubbing alcohol dry very fast when exposed to air.
Old Oct 11, 2003 | 10:52 PM
Seal's Avatar
so here is what i gotta do...
take the whole thing apart, and MAKE sure i dont touch the wires...
and i clean the inside of the MAF with some electrical cleaner... and the resistors, with a qtip... (can i use qtip on the resistors, or are those 3 lil wires are the resistors) well, lemme put it this way.. what can i qtip, and what can i not? (pic would help, dont wanna mess this thing up)
and here is teh important part... i cant touch the 3 lil wires in there, but just spray them with electrical cleaner, and make sure they go perfectly dry right? (clean it with the spray, as if air was flowing through it, and it will dry itself clean)
95blkss
Parts Wanted
Jul 19, 2015 08:42 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Noct
Jul 14, 2015 01:18 AM
