Should i switch to vented opti or not ?
Old Oct 9, 2003 | 10:02 PM
JustAnotherGuy's Avatar
Well im gonna do a cam swap in December and im gonna replace my opti since it has around 100k miles on it . i was just wondering should i switch to a vented opti while im doing this or just say with a non vented.
sry i did not look this up but between school and work i dont have much free time
Thanks for any help.
Old Oct 9, 2003 | 10:08 PM
Seal's Avatar
its not only the opti change if youre going to change to a vented one...
alot of other things, like timing cover and blah blah, i cant exactly remember what else, but theres alot to change... do a search :P
i think there is a company that does vented opti that will bolt on to pre 95s
Old Oct 9, 2003 | 10:09 PM
The vented opti will be cheaper, but you will have to buy just a few more things. If your decide to change, make sure you get a cam that has the larger hole in the front.
More info:
http://para.noid.org/~muttvette/opti.html
Old Oct 9, 2003 | 10:11 PM
Fatdog's Avatar
Cool
I would do the water pump first.Maybe the opti(your choice).I'm still on the factory 107,000,but it will problably die next week.Hope this helps.
Old Oct 9, 2003 | 10:27 PM
chesee48's Avatar
You mind as well change everything while u are at it. At least i was when i was gonna do my cam swap.
Waterpump
Timing Chain/Cover, Gear
Opti
with the vented opti, u need a 95+ harness, cover etc..
do a search and you'll find TONS of posts that lists everything
Old Oct 9, 2003 | 10:46 PM
DarkRider's Avatar
The company that offers the vented opti that will bolt right up to the pre 95's is dynotech www.dynotech-eng.com/dynaspark.htm it is $600
Old Oct 10, 2003 | 11:31 AM
Thanks fer all the help and i had already planed on changing the water pump dont want my new opti to die on me
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
thenewkid
Nov 27, 2014 09:41 AM
