how to replace TPS
Old Oct 10, 2003 | 06:55 PM
Seal's Avatar
how to replace TPS
ok, couple Qs...
where is it on the tb? (pic would help alot)
how do i change it?
how hard is it? (do i gotta take the tb off?)
Old Oct 10, 2003 | 07:00 PM
It is here .
Disconnect electrical connector, unscrew torx mounting screws. pull out. Install in reverse order, lining up tang on TB to the sensor.
No need to remove TB.
They rarely go bad. Do you know it has a problem?
Old Oct 10, 2003 | 07:06 PM
Seal's Avatar
the SES popped a light saying i'm getting low voltage... what else can it be, any ideas?
jackpawt883
Feb 26, 2015 09:04 PM
armedtrigger
Feb 24, 2015 08:30 PM
grgguy
17
Feb 23, 2015 07:57 PM
edman
Jan 22, 2015 02:45 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
