Car backfires when reving
Old Oct 11, 2003 | 08:34 PM
WhiteBeast's Avatar
Question Car backfires when reving
Well, I am not complaining about it that much because i dont really rev my engine up. But when i do rev it up it has a few small backfires to it.
What could cause this? Right now i have a stock exhaust except for a turbo muffler.
Old Oct 11, 2003 | 08:39 PM
NewbieWar's Avatar
well, mine backfires but only when in gear and im thinking its opti
Old Oct 11, 2003 | 09:47 PM
S8ER95Z's Avatar
Leak in the exhaust somewhere? My leaking manifolds backfired bad. Intake leak? Coil Wire? (Does your Amp gauge move / lights dim ?)
Old Oct 11, 2003 | 10:31 PM
WhiteBeast's Avatar
Well, I do have a torn intake elbow, and plan on buying a new one soon. I also have a leak in my intake somewhere.
It is pretty loud hissing sound. It seems like it is coming from the area where in the front of the intake where the little bar seems like it connecting the 2 fuel rails.
Anyway Could this be causing my backfire(s)? And is it bad for performance or the engine.
I probably will have to replace my intake manifold huh?
Old Oct 12, 2003 | 06:26 AM
revtime's Avatar
Is it backfiring as you rev it up or after you let off?
Old Oct 12, 2003 | 11:12 AM
WhiteBeast's Avatar
IT is backfiring after i let off of the gas.
Old Oct 12, 2003 | 06:46 PM
revtime's Avatar
Most likely an exhaust leak.
Old Oct 12, 2003 | 09:37 PM
WhiteBeast's Avatar
What about performance? Will having an exhaust leak that will cause the exhaust to pop and backfire when after reving rob my engine of that much power?
Old Oct 12, 2003 | 10:16 PM
NewbieWar's Avatar
i donno man, i think i got an exhaust leak in my EGR but, it seems to me like everything is functioning right
besides a slight hissing sound
Old Oct 12, 2003 | 10:24 PM
S8ER95Z's Avatar
Something else I just thought of.... When mine did it really bad...the EGR Tube was broken off! It was not only leaking exhaust..it was pulling air into the intake from the outside.
Old Oct 13, 2003 | 12:07 AM
WhiteBeast's Avatar
Well the past few weeks i have been getting a SES code that was for the EGR. I found that a hose had been disconnected and so i reconnected it. The SES code still came on for a few times after that, but it has not came on in about 4 days now.
So, do you think there could still be a problem with my EGR assembly?
I will have to check it all out tomorow.
bfmv13trivium
Jan 14, 2015 09:57 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
F(ast)-body
Feb 26, 2003 09:05 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
