Doing lowering springs tommorow?
Old Oct 11, 2003 | 05:56 PM
AustinZ28's Avatar
I was looking for a good install page or something on putting in these lowering springs I just bought. I did a search and didn't really find a good source for a 4th gen. I am putting in 2 inch Intrax lowering springs and KYB AGX adjustable gas shocks. Can anyone help me out? I did the Steeda lowering springs on my Mustang no problem, but I had instuctions. Thanks --------> Brad
Old Oct 11, 2003 | 05:58 PM
Z95m6's Avatar
i believe brent has one.
Old Oct 11, 2003 | 06:00 PM
AustinZ28's Avatar
Could you maybe throw me a link? Not sure how to get to Brent's homepage. Thanks--------------> Brad
Old Oct 11, 2003 | 06:08 PM
Z95m6's Avatar
http://www.bfranker.badz28.com/fbody/guides.htm
He is the moderator here. His name is listed at the top of this forum just click it and it will take you to his profile with a link to his site.
Old Oct 11, 2003 | 06:47 PM
AustinZ28's Avatar
Yep he has one for a set of Eibachs with Hal shocks, its very confusing, if you don't have this, do this, ect...... Also the other link for a 4th gen spring install does not work.. Does anyone have something a little more informative about all shocks/struts. Thanks------------> Brad
Old Oct 11, 2003 | 07:11 PM
jkipp84's Avatar
Injuneer has this one. Might be of some help..
Old Oct 11, 2003 | 07:42 PM
Pretty sure that is the Hal/Eibach one that he said was confusing (though I don't know why).
AustinZ28:
Didn't I see another post where it looked like you just ordered shocks or do you already have them? There is no point in doing the springs if you don't have the shocks. The fronts are coil-over shocks and you would have to disassemble them all over again to put the springs on.
Old Oct 11, 2003 | 08:21 PM
AustinZ28's Avatar
OK I think I get the jist of what to do. Right now I cant afford an adjustable PHB (?) for the rear end or the relocation brackets for the LCAs (?) I think that is all I need to properly lower it?. Will it be alright to just put in the springs, shocks and get an alignment then wait a few weeks to install the other stuff mentioned above? --------> Brad
Old Oct 11, 2003 | 08:27 PM
Neither of those things are required for a lowered car-just recommended.
Old Oct 11, 2003 | 09:40 PM
carlos64030's Avatar
It's really a straight forward job. Pick up a Haynes manual to assist you...everyone that works own their own car should have one to refer to.
Old Oct 11, 2003 | 10:20 PM
AustinZ28's Avatar
great guys thanks for the help. -------> Brad
Old Oct 11, 2003 | 10:22 PM
AustinZ28's Avatar
So if I never get them, it won't effect anything? Will I be able to get an alignment with out them or will lowering eat my tires? -----Thanks -->Brad
Old Oct 11, 2003 | 10:43 PM
After lowering, get the car aligned to whatever specs you decide. Lowering mostly causes excess negative camber. Adding the adjustable PHR and LCA brackets won't bother the front alignment.
Old Oct 11, 2003 | 10:45 PM
AustinZ28's Avatar
Thanks bro, you are truely appreciated around here. ---------> Brad
Noenav
Mar 1, 2019 07:38 AM
thenewkid
Apr 12, 2015 07:42 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
