dumb question. whats the difference between short and long blocks
Old Oct 9, 2003 | 12:41 PM
ZDriver96's Avatar
Old Oct 9, 2003 | 12:45 PM
IslandZ's Avatar
A shortblock is a block without the head(s) and a long block is the whole block plus head(s).
Old Oct 9, 2003 | 12:46 PM
Z95m6's Avatar
i believe a short block is a complete block, rods, pistons,cam but no heads or intake. long block has heads, and maybe intake.
battosai's Avatar
I believe a short block is just the block, crank, and cam. Where as a long block is that, plus the pistons and heads. But I'm not 100% sure on that.
Edit: danm got instatposted
Old Oct 9, 2003 | 12:47 PM
ZDriver96's Avatar
so all the engines in our cars are considered long blocks right now??
so if someone were to say they had a shortblock in there car with heads on it they'd be incorrect?
Old Oct 9, 2003 | 01:46 PM
dnz28's Avatar
The engines in your car now are considered to be turn key engines.
Old Oct 9, 2003 | 01:53 PM
Hawk95's Avatar
A short block is the basic rotating assembly and is considered the 'lower' portion of your engine. A long block is a short block with heads (and valve train) and sometimes valve covers. This terminology is used when buying/selling engines. Also note that there are also small and large blocks which refer to displacement. Hope this helps.
Old Oct 9, 2003 | 01:55 PM
NewbieWar's Avatar
ok now we got a 3rd kind of engine ohh no
Old Oct 9, 2003 | 02:12 PM
ZDriver96's Avatar
ive always known the difference between the big blocks and the small blocks in general..
Thanks for clearing up the short/long block dicussion.
But when does a small block become a big block? What are the requirements?
Old Oct 9, 2003 | 02:21 PM
Hawk95's Avatar
I think the barrier between small and big block is with a small, usually it is a certain size casting that is bored to meet displacement requirements, like how a 327ci can be bored to say 350, and a 350 to 383. I think when the cast of the block needs to be larger to meet these displacement requirements, it becomes a big block, like with a 454 or 426. They actually need to create a new, larger cast for the block itself.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Sergio
Jan 27, 2016 04:27 PM
Decromin
Aug 18, 2002 10:11 AM
