847 and cc 306 guys
847 and cc 306 guys
im not sure if he is milling them or not but im having a set of stock lt1 heads ported and he is gonna put bigger valves in them. 2.00/1.60's i think. will that be to big for the stock bottom end with a cam and 1.6 rr? and 2. what are the specs and part number on the gm 847 cam i havent heard of that one yet. i was considering the cc 306 but im open to whatever is best. i have crane springs part #10308-1..will these be good enough to support either of these cams? last of all if any of you have sound clips send away
grease i tried to email you but it keeps coming back!!
GM 847 cam is 234/242@.050 duration and lift is 575/595 with a 1.6 rr all with stock bottom end hearmods in sig any questions email me ... I would get your flow #s from your heads and custom taylor a cam to how they flow IMO.... good luck
here you go 1badasZ www.gmpartsdirect.com is where you will find the cam
carguy0119
Apr 11, 2016 11:11 PM
mspennyhughes
Nov 28, 2014 03:22 PM
