OK to "hoist" car up by bumper support?
Old Oct 9, 2003 | 05:21 PM
Mullet Z28's Avatar
I pulled the motor from the bottom and it's ready to go back in soon. Is the bumper support sturdy enough to hook the cherry picker up to? I know it's only held on by four bolts. Any other suggestions?
Old Oct 9, 2003 | 06:24 PM
Birdman7389's Avatar
run it to the K-member if the engine is out??
Old Oct 9, 2003 | 06:50 PM
Z95m6's Avatar
I took a short chain and bolted it to both shock towers. The car weighs nothing on the front end when the kmember is out. I lifted mine up that way and moved it around that way.
Old Oct 10, 2003 | 12:56 PM
Mullet Z28's Avatar
Birdman, the engine is out with the k-member. I'm going to put the motor back on the k-member, then slide both back into place from the bottom.
What size bolts did you use for the shock towers?
Old Oct 10, 2003 | 01:33 PM
Z95m6's Avatar
I would use the biggest you can get to fit through the holes and the chain. I believe i got away with 3/8 inch grade 8's. Probably not to many 7/16's bolts that will fit through the chain.
Old Oct 13, 2003 | 07:58 AM
DOH! I mised the part about coming out through the bottom...sorry
Old Oct 16, 2003 | 03:41 PM
Mullet Z28's Avatar
FYI:
The bumper supports are plenty stout to do this. Worked great.
Old Oct 16, 2003 | 04:52 PM
Cory_SS's Avatar
FYI:
I thought about doing this but wasn’t sure. What part did you hook onto? The metal support that the hood latch is connected too?
Jazsun
Dec 29, 2014 12:14 PM
CARiD
Dec 26, 2014 04:20 AM
heavenly_six
Dec 10, 2014 12:23 AM
USAirman93
Nov 24, 2014 03:37 PM
BLOWNBIRD
May 28, 2003 01:02 AM
