windows scratched
Old Oct 10, 2003 | 07:46 PM
Donohue96M6Z28's Avatar
windows scratched
hey just a quick question..ive had two z28's and they both have the windows getting scratched...whats an easy way to fix it...it annoys me sooo much...on one of the camaros i took these two felt material guides out that were riveted in to the door...but i couldnt put nething else there in its place...what could i do?? thanks...i know its a problem in most camaros and trans ams...thanks
Old Oct 10, 2003 | 07:51 PM
Cmr0z28's Avatar
I had that problem......fugged up my tints on the driver side pretty bad
Those little gold mounting things that are riveted into the door, one of them broke in half and I found it inside the door when changing my window motor.....the part with the felt end broke off and the bare sharp metal was scratching my window, so I took them off, brought it to the dealer, got new ones, and put them on. Now all is good!
good luck!
Old Oct 10, 2003 | 07:58 PM
was it scratching the inside of the window?? mines scratching the outside...how much did the dealer charge you?? thanks for you help man
Old Oct 10, 2003 | 08:04 PM
Cmr0z28's Avatar
you're welcome!
mine are scratching on the outside as well, but its not even noticeable, only if you see it at the right angle so I never bothered fixing it.....but the ones for the inside were only a few bucks a piece....it wasn't much but i don't remember the exact amount.
Old Oct 10, 2003 | 08:07 PM
Z95m6's Avatar
if it is the outside it is probably the weatherstripping. I think it is about 50 bucks a side at your local dealer. It puts scratches on your window in several vertical scratches a few inches apart from eachother on the back half of the window.
Old Oct 10, 2003 | 08:08 PM
alright thanks...ya tha scratched jus annoy me eveerytime i c them u know..thanks for the help...ttyl
OutlawPerforman
Oct 30, 2017 05:40 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
z28cam1993
Sep 9, 2015 04:08 AM
Jul 10, 2015 02:23 PM
