AS&M header guys.NEED HELP
Old Oct 9, 2003 | 12:14 PM
ledfootz28's Avatar
i have the as&m headers and my #6 wire was burnt through the coating.their accel 300+ wires and it was just sitting on the header tube.problem is i cant even see the wire boot from the top to take it off the plug.how do i get this wire off?is it possible to go through the bottom??any tips appreciated.
Old Oct 9, 2003 | 07:43 PM
M93Z's Avatar
I just installed my wires today. I ran all of the wires on the right side [2,4,6,8] below the headers. 6 & 8 were a little too close to the header running over the top, 2 & 4 can go either way so I just ran them all underneath. Left side I ran 1 & 3 underneath and 5 & 7 over the top. I also installed fiberglass boot protectors on the wires. It's fairly easy if you pull the starter & Y-pipe. Hope this helps.
Old Oct 10, 2003 | 12:50 PM
ledfootz28's Avatar
yea ive had the as&m for almost a year now but i just recently burned the 8+6 wire.i got the 8 fixed but i cant get a good grip on teh 6 boot.ive tried from the top and from the bottom with no luck.im not gonna drop the y pipe and starter to change the wire.if i cant get it i ll just have to take it to the gas station i work at with a lift.
Old Oct 10, 2003 | 04:24 PM
Fastbird93's Avatar
I have the Over the Valve Cover kit on my car with the ASM's. Originally, I had the #6 wire routed over to the shock tower, and the down and under. Now, I've got it routed kinda behind the dipstick and straight down to the plug. No problems noted.
Old Oct 10, 2003 | 04:43 PM
ledfootz28's Avatar
i think im gonna take it to my work and the ll just have to take the oil dipstick out to get a good grip on it. i really dont feel like messin wit it anymore and over the valve covers is teh way to go.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
