crank hub re-installation question
Old Oct 10, 2003 | 04:57 PM
brandboZ28's Avatar
I didnt mark the hub before I took it off so how exactly would I put the hub back on to make sure everything will line up as far as timing goes? Right now it is in #6 TDC. If I get it to #1 TDC, which way would the "aarow" on the crank hub instelf point? Thanks.
Bo
Old Oct 10, 2003 | 04:59 PM
12SCNDZ's Avatar
With #1 at TDC, the arrow should point straight up (12 o'clock)
Frank
Old Oct 10, 2003 | 05:01 PM
brandboZ28's Avatar
That was the quickest reply ever, you are my hero. Thanks
Bo
Old Oct 10, 2003 | 05:03 PM
anaik's Avatar
The arrow is straight up with either #1 or #6 at TDC, so you're alright where you're at.
Old Oct 10, 2003 | 05:04 PM
doodad's Avatar
When doing a cam swap, the crank hub should point in the direction of the "Bainbridge lean" which will insure a straight run at the track this weekend. This might overcome friends who run spray to keep suprises to a minimum.
97Camaro007's Avatar
Is this important that it is on right....i mean i don't think that mine is on correct but runs fine.....not to steal your thread or anything
Old Oct 10, 2003 | 05:08 PM
anaik's Avatar
It is just used as a reference for 1 or 6 being at TDC.
Old Oct 10, 2003 | 05:13 PM
doodad's Avatar
It is ok to steal his thread. In fact, let's talk about the weather. Or the Red Sox vs Yankees. Or...banana peels.
Old Oct 10, 2003 | 05:47 PM
brandboZ28's Avatar
Well now that I have the timing issue taken care of, I cant get the bolt back out of the crank. I dont want to musce it around to much because I really, REALLY dont want to break it off in there. Any ideas here?
EDIT---Got the bolt out and buying a new one.
And Bart, I live in Tallahassee. And given that I fix this little problem that I have brought upon myself, Im gonna have some fun come Sunday.
Old Oct 10, 2003 | 07:11 PM
doodad's Avatar
Oh then Tallahassee tilt it is. Sigh...guess I get to see tail lights again doggoneit.
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
