Insulation on O2 sensor harness is open
Old Oct 9, 2003 | 10:47 PM
$hawn's Avatar
Installing my headers, and when I disconnected the passenger side O2 sensor harness I noticed a slice in the insulation. From my scanner readings it seemed to be working ok last I checked, so do you think it's not shorting out, can it? I really dont want to cut it and reconnect it, so should I just put tape over it?
Old Oct 9, 2003 | 11:00 PM
Try to repair the insulation. If the wire is not frayed or broken, it will work unless it touches something and grounds out. You might consider a piece of heat sleeve or something to protect it further after you repair the insulation.
oldschool
Feb 9, 2016 09:21 PM
eazyZ
Mar 1, 2015 07:12 AM
cmdeshon
Jan 4, 2015 11:15 AM
