type of metal are 93 lt1 rods?
Old Oct 9, 2003 | 05:25 PM
INFERNO's Avatar
What type of metal are the rods in a 93 Lt1 made of?
Old Oct 9, 2003 | 05:27 PM
RamAir95TA's Avatar
Forged powdered metal.
Old Oct 10, 2003 | 09:07 AM
Z-RATED94's Avatar
I thought they didn't start using PM rods until late 94 or early 95? I could be wrong, it's happened once or twice before.
Old Oct 10, 2003 | 09:57 AM
From the often quoted "Rebuilding the LT1" article:
RODS
350 - The original LT1 came with regular forged 350 rods, that were shot peened for localized hardness under the head of the bolt and nut. Powdered metal rods were phased in for the Corvette around 1994 and used in all of the LT1 engines by 1995. GM made the change because the powdered metal rods were cheaper to make and were much stronger than the GM high performance "pink" rods. In fact, they are supposed to be good for up to 450 hp. They are machined at the parting line so they can be reconditioned.
Not sure how accurate the info is, but most of what is in the article seems to be correct.
Old Oct 20, 2003 | 11:44 AM
marshall93z's Avatar
i always thought the pink rods were an upgrade from the stockers. i just bought a rotating assembly from a friend that had pink rods in it and he put down 615rwhp with no problems.
im going to use them in a nitrous motor so i may change them anyways.
Old Oct 21, 2003 | 09:28 AM
Z-RATED94's Avatar
marshall93z,
615rwhp on the pink rods? I believe there's a saying for that. It's called (pushing your luck). Then again, maybe he changed them out after every pass or dyno run.
Old Oct 21, 2003 | 10:12 AM
nah, he ran it for a little while then went with a stroker. i bought his old stuff from him. im going to see how much n20 power they can stand.
LeftoverChinese
Jan 14, 2024 03:03 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
