93 Oil life question...
Old Oct 11, 2003 | 05:22 PM
HM Murdock's Avatar
OK, apparently 93's had the oil life indicator on the cluster, and in OBD1 95's, there is a code for oil life that is factory disabled. Will enabling this enable the indicator on the dash?
TIA.
Old Oct 13, 2003 | 11:21 PM
HM Murdock's Avatar
Any ideas?
Old Oct 13, 2003 | 11:23 PM
marshall93z's Avatar
ive never seen it on my 93
Old Oct 13, 2003 | 11:32 PM
HM Murdock's Avatar
Hmmm...It's up in the upper left of the cluster, it says pretty clearly "Change Oil"....Weird...
Old Oct 14, 2003 | 12:32 AM
Ace_437's Avatar
I've never seen, or heard, of it either. I don't know how it would work anyway. How would it know when you changed the oil?
Old Oct 14, 2003 | 01:26 AM
Bud M's Avatar
Maybe they planned to use it but then decided not to. Mine (if I have one) has never lit. If it did I guess you would need to reset something at each oil change.
I'd say we're better off without it. My sister in law has a BMW with that feature. She pays $80 for an oil change at the dealer so they can reset it. I would feel like a sucker that was my car.
Old Oct 14, 2003 | 01:54 AM
HM Murdock's Avatar
I know the 99 and ups have it, but they are OBDII LS1's...I'll take a pic of it tomorrow for reference. BTW, DTC 95 in tunercat says "Oil Life Diagnostic" , I turned it on to see what happened, nothing yet, obviously.
Old Oct 14, 2003 | 03:36 AM
Fastbird93's Avatar
My 93 T/A owners manual doesn't say anything about an oil life indicator.
Old Oct 14, 2003 | 03:39 AM
HM Murdock's Avatar
Well, this is a Z28 150mph cluster...Might make a difference.
Old Oct 14, 2003 | 10:01 AM
Ace_437's Avatar
Nope, it doesn't.
Old Oct 14, 2003 | 11:41 AM
nope, mine definitely doesnt have it...
Old Oct 14, 2003 | 12:09 PM
HM Murdock's Avatar
http://hometown.aol.com/prwarnke/ima...life%20004.jpg
Upper left side...
Old Oct 14, 2003 | 06:25 PM
Ace_437's Avatar
It's there, but no bulb for it. It has no real use.
Old Oct 15, 2003 | 12:24 AM
HM Murdock's Avatar
OK, That makes some sense. It's like GM had it put in, but then decided not to use it.
Old Oct 15, 2003 | 01:05 AM
93formula's Avatar
they all have it, its there, sometimes its easier to look at it from the back. the bulb is missing for it. i guess it was there just in case but never used. on the firebirds its on the lower right corner. i dont think activating it will do anything cause there is no bulb or sensor in the oil pan. i believe the senso works on teh new cars by picking up metal deposits in the oil via some sort of magnet. i may be way off base here
