Need help with keyless entry (shoebox)
I have keyless entry, but i bought a gm alarm that tapes into it.
Does anyone have a diagram of the keyless entry brain and what each wire goes to, such as trunk release etc..
Just for you: 1995 Keyless entry schematic. The 1994 and 1995's are mostly the same when it comes to wiring.
Sorry, you asked for a diagram. It's a little hard to give a tutorial on how to read a schematic over the internet.
I thought that maybe there was some wiring info with the alarm that might help you mate it up with this schematic.
In the schematic, there are letters by where the wires go into the receiver. Those correspond to cavities that are marked on the connectors that plug into it. If you see a C1 or C2 by it, that means connector 1 or 2. You can follow the lines for power and ground to the various items that are controlled by the receiver.
I thought that maybe there was some wiring info with the alarm that might help you mate it up with this schematic.In the schematic, there are letters by where the wires go into the receiver. Those correspond to cavities that are marked on the connectors that plug into it. If you see a C1 or C2 by it, that means connector 1 or 2. You can follow the lines for power and ground to the various items that are controlled by the receiver.
heres a pic of what im dealing with. I know that those wires go out to the doors, trunk, etc, i just nead to know what is what so i can tap into it for the alarm
Linky : http://f1.pg.photos.yahoo.com/ph/ou_...iew=t&.hires=t
Well, the schematic shows what connector, what color wire and where each goes. I'm kinda at a loss as to how to help you more than that.
ex. On connector C2, C is a grey wire and G is a tan wire-they go to the LH power door lock actuator.
C2, H is a tan wire and a grey wire that is spliced off of C go to the RH door lock actuator.
The hatch release relay (not the one inside the receiver) is operated by C1, B that is a black wire.
actually, that REALLY helps. Now i know what to tap into.
Im never good at looking at those kind of schematics
, thanks alot shoebox
gelbza
Jul 12, 2015 08:10 AM
