View Full Version : LT1 Based Engine Tech
- Street Twin install.
- Help on Thermostat
- Long tube headers on a daily driver
- OVC wires, coil and what else?
- Oil Pan Gaskets
- rpm drops when turning steering wheel?
- How to install a ABS Reluctor Ring
- Hotcam idle... ?
- Lt1 Gear Drive(timing)
- FIXED!!!!!!!!!!! Well, almost.....
- 977 springs...to much presure?
- lobe difference on the 306 and 847
- About to install my LCAs, any tips or tricks?
- Car misfires/backfires
- What does the wire that hooks to the AC do?
- Cold start bottom end rattle.....
- Quick question!
- code 48 and occasional stalling at stoplights
- Pan clearance w/tubular K
- $10,000 ballpark for LT1 Rebuild?? about right??
- Head Gasket?
- adjusting panhard???
- i have a question.....
- Car still won't start, can't be Opti, can it?
- gears tc vs. hotcam headers
- Rear window seal
- Talk to me about fuel pumps
- anyone have,zo6 maf from ls1speed.com
- Valve lash.....this is kilin me.
- Bad Opti??Please help
- EGR Vavle...Can i clean it?
- Are speed pro pistons anygood?
- supercharger
- What exactly is the diff in an lt1 block and a standard sbc block?
- LT4 converted drivability issues
- Anyone have CMotorsports AFR Heads?
- Reusing my stock 75k lifters...
- weird problem??
- Question about our fuel systems... why the U turn in the fuel hoses?
- what is the absolute easiest way to make 450rwhp w/o spraying?
- Stock Coil vs Aftermarket Coil
- Transmission Shifts not good
- Coatings ?
- Rookie Advice
- people with 93s (speed denstity)
- SPEC Stage 3 Ceramic on Stock LT1 flywheel - not a good idea?
- The ceiling is coming down!
- Testimonial to aftermarket Ignition Systems
- LT4 KM Install
- Low RPM's
- Vats!!!!!!!
- 383 Vibration problems
- code=o42
- My stupid theroy. If we had 1.4 Rocker Arms, would that help to pass Emmisions ?
- cooling car for the 1/4
- Timing marks
- Hooking up PC to car?
- 1.6 rr with what springs??
- im using a 20 year old IAC!!!
- Will a 225/60/16 tire throw my speedo off?
- Motor oil question (Mobil 1 and others?)
- 1/4 mile times need help
- I turned the key in the ignition, the dash lit up, but the starter didn't go
- 2 Questions-battery and oil pressure
- LT4 Knock Module
- What Ya'll Think Rwhp#'s Will Be?
- High pressure hose with HP 255lph Walbro
- BAD! water pump
- Pcmforless
- Need help changing transmission fluid
- i seated my rings tonight (not in a good way)
- Brake pedal squeak when applied
- "Street ported heads" They worth the time/money???
- Extreme Duty guys in here ...
- Optispark seal would not come out!!!
- Best parts to buy for the money????
- Gear Install Experts Inside
- Started the Z for the first time in over a month, shakes like crazy?
- et times
- High rpm mis??????
- Headers
- O2's for Long Tubes
- lt4 intake
- backseat floor fills with water after rain,dry all around and above though?
- how do i get ahold of jason cromer
- stock crank replacement
- squeek squeek squeek
- 96 keyed crank hub with washer???
- Do you think I should replace or repair the bumper skin?
- guide plates.......need help quick
- jethot primary leak is too irritating
- Cam experts come on in. Torque band question.
- t56
- strange spark plugs... some burned some fouled
- High RPMs
- EGR Delete People Inside....
- How do I tell what gear ratio is in my TA's rear ?
- Stroker guys is this a good ebay buy?
- help? please
- This is the surge that never ends!
- Camshaft question
- Can you run a ZZ4 cam in an LT1?
- Auburn rearend noise?
- 383 Wont Start, Need help fast.
- Need help with pushrods lenght selection!
- Car was wrecked... Getting it back tomorrow, anything to look for?
- HELP! Burning Smell at WOT
- OK i think this is happening AGAIN!!!
- Best cheap street tires?
- ??windshield wipers??
- Head expert in here
- CC306 Time Slips????
- $300 Brake upgrade
- Faulty ACDelco??
- Weird surging and power loss after cam install, help plz...
- What are the most important suspension mods?
- Stock LT1 spark plugs wires, part#?
- What would you do for a good tune up?
- Trans Leak
- Car won't start!!!
- KS Desensitization, one small question.....
- Urgent re-build questions
- Are the new LCAs going to hurt ride quality?
- Stock Driveshaft?
- RWHP gain going from 1.5 to 1.7rr on stock cam/heads?
- Funky noise from rear
- power steering issue
- Power Steering Pump
- Anyone know the part # for NGK-TR55s at Summit?
- north jersey motor rebuild?
- Cat gone bad
- Opinions on this 93 Z28
- How high to jack the motor for the oil pan...
- Utility for plotting graph of cam/valve events?
- Tranny Cooler
- ODD problem never expeirenced!!
- Anyone change their battery base???
- Power Surges!?
- Opti Q's
- Torque Converter Video
- Backpressure
- ls1 cai to lt1 cai
- Chrome Moly or Mild Steel ? URGENT!!! Please Help.
- smaller dia. available for LT1?
- Just got my LM on
- f/s: 94 z28 make offer
- I Learned a Lesson Today
- 7.8" Oil filter
- How good is tunercat??
- need list of cams and specs for them.
- vapor canister unhooked
- It's back!!
- rear defog problem
- edelbrock header ?
- How do you remove the CPS reluctor wheel???
- TC and daily driving
- Mufflex 3.5 inch off road Y-pipe
- $650 for junkyard LT1?
- WHERE CAN I GET 1.7 rr's for lt1?
- how to remove / reinstall portion of steering knuckle?
- AC delete questions
- Side mount OVC wires
- Headers and exhaust
- Damage from Bottoming out...
- Over Heating
- advantages of true duals over the y-pipe
- MPG with 4.10's and 3.73's
- searching didnt help so dont flame me
- Hooker, magnaflow, or electronic cutout?
- Which gear is more quiet: Motive, or Strange?
- what cam to use
- GM847 vs. CC306
- reset computer?
- Longtubes with dual cats need pics
- 1.7 Rr With Solid Roller Cam?
- Changing to 160 thermostat
- Is this exhaust setup idea possible?
- can computer go bad-car wont start
- knock sensors and OBD1 conversion
- Steering Rack Length
- IS A Chip worth it?
- Scanmaster w/ ODBI conversion
- Bullet to LM
- built 383, H/C
- sputtering, backfiring
- going from power to manual brakes??
- Who's tuning your LT1?
- Grrrr, car very hard to start, help!
- How do you remove ati damper?
- is there a way to rewire the foglight switch to turn on without the parking lights on
- Thermal Pictures of Motor/Car
- 4L60E to TH400?
- heater not warm
- Engine setup help.....
- LT1/LS1 coil pack conversion dyno results?
- car is in park but wheels still spin!!!!!!!
- Whats the safest way to turn the crankshaft??
- Is it okay to put thin layer of RTV between CSI pump and housing???
- where is TA logo on the front???
- airfoil that goes on the TB worth 6rwhp???
- brakes not working fully?
- Leaky injector
- A/C Heater probs
- Low coolant?
- Can the Emmisions test guy pass any car ?
- Stock Ported LT1 Heads vs. Aftermarket heads
- Why can't I find a stock LT1 dyno curve?
- will 97 TA speedo fit 96?
- Car won't start need help
- Can I use block sealer/radiator sealer in my car?
- Front swaybar and lowering question
- What size fuel injectors?????? HELP!!
- Is it possible to swap out the digital odometers?
- SFC's and LCA's???
- Automatic door locks are not operational
- high temp paint??
- Can I change the color of the LT4 intake
- people with cutout...seems slower?
- I'm at a loss here
- Torque arm question?
- Waterpump
- 17" wheels wont affect odometer will it?
- Question about LT4 KMs
- Performance chips
- TPiS LT's
- rough start
- Who uses OVC wires?
- Which Forged Pistons?
- knock retard help
- This look like a good winter mod list?
- Need vacuum diagram or pics, plz :)
- i want lowering springs but.......
- What is the biggest wheel stud I can use with stock wheels?
- Specs on the GM 8xx cam?
- colder cai???????
- Help I need 2 nuts!
- Sqeaky wheel
- will be removing dash and steering wheel
- Would these wheels work for this tire?
- Quick Reply Needed - Water Pump Installation
- Need to test radiator...... Help plz!
- Hotcam or CC305?
- 383 clearence issues
- CAR will NOT FIRE. for some reason
- You don't have to remove the alternator to pull the pass valve cover
- #########O2 Problem#######
- Need info on 383 swap
- EGR and AIR block off?
- Power Window Motor?
- new exhaust!
