LT4 KM Install
Old Nov 7, 2003 | 06:55 AM
SSGurl's Avatar
LT4 KM Install
Ive had my mods (headers, cam, etc) on for a month or so and now Im just getting around to changing my Knock Module. If I am picking up false knock now and I swap this module out does it immediately correct it? Ive heard that pcms "learn" and so if I disconnect the battery and replace this is that all I do?
Old Nov 7, 2003 | 07:01 AM
grygst76's Avatar
Re: LT4 KM Install
Take the PCM fuse out, it's much easier then battery disconnect....If you are getting false knock it depends how severe it is, otherwise the LT4 KM will help significantly.
Old Nov 7, 2003 | 07:31 AM
joeSS97's Avatar
You should notice it immediatly.at least I did.I disconnected the battery.Its an easy install,either way.
Old Nov 7, 2003 | 07:40 AM
http://www.projecttransam.com/projects1.asp
LeftoverChinese
Jan 14, 2024 03:03 PM
4586
Nov 18, 2023 07:21 PM
GigaMp3z
Feb 20, 2003 02:57 PM
