Waterpump
Old Nov 4, 2003 | 08:21 PM
1FstFormulaV8's Avatar
Waterpump
My water pump is REALLY REALLY hot, and the car wasn't even idling for 5 minutes..Is this normal..And..could someone tell me when I take off the Opti. what do I do with the dowel pin, if it's either in the cam or still in the opti. I'm confused. Help would be great.
Old Nov 4, 2003 | 08:24 PM
Josh-'04 GTO's Avatar
When you remove the Opti, the dowel pin stays in the camshaft snout.
As for the waterpump temp, what coolant temp is the guage reading?
Old Nov 4, 2003 | 08:36 PM
It was a little above 100. And what if the Pin is still in the opti with I remove it..Sorry about these two part questions.
Old Nov 4, 2003 | 09:10 PM
Dave89IROC's Avatar
your 93 doesnt use the dowel to drive the opti, it uses a slines stub shaft, which could stay in the opti or cam, it just slides in
reww86
Aug 29, 2015 06:04 PM
MikeWhitener
Aug 2, 2015 06:17 PM
jwade88
Jun 14, 2015 09:38 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
