BAD! water pump
BAD! water pump
ok guys im in the middle of fixin/replaceing a water pump
ive removed all the hoses that where in my way and all the screws it still wont budge
???? how can i get it off
also if any one has one of those mechanic books if you could scan up or type up the instructions thatd be great
damn water pump
damn water pump
remove the applicable bolts. Seriously, there is 2 bolts?and a nut that is attached to a stud which runs through the water pump. I'm sorry I just told you how to take the bracket off. First you have to remove the 10mm screws that attach the rubber mounts to the bracket.(3 of them) remove A.I.R. pump then bracket. make sure you got the fan out of the way the three bolts on the pass. side and pull.
Magenta_Hearts
Mar 29, 2017 08:54 PM
