About to install my LCAs, any tips or tricks?
Old Nov 7, 2003 | 05:50 PM
94 CAMRO Z28's Avatar
They are BMR boxed control arms. Is this as simple as it looks? Do I need to suppor the rear end of the car or axle at all or do I just unbolt and bolt in the new ones? Thanks
Aaron
Old Nov 7, 2003 | 07:18 PM
TW95Z's Avatar
Having the car up in the air makes it easier to work on. I put the car on jack stands located just in front of the LCA mount on the body. Replace one side at a time. You just don't want the rear to rotate and let a spring fly out, but with the torque arm, and shocks connected, and replacing one LCA at a time that won't happen.
Old Nov 7, 2003 | 07:31 PM
1FASASZ's Avatar
i just put the same ones on last night it was realy easy they bolt right up. i put jackstands under the back and left the front on the ground. good luck
Old Nov 7, 2003 | 07:34 PM
Transamdriver's Avatar
Dont support the axle, and take nuts off off both of the bolts before you try to get the bolts out it makes it a ton easier, mine kept getting pinched when I tried one at a time. Then put the new ones on and then load the suspension and tighten the bolts and add a shot of grease to each bushing and you are ready to go.
Nov 18, 2023 07:21 PM
BinkZ28
Apr 20, 2015 09:10 PM
ModdedNerd
Feb 20, 2015 10:39 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
