advantages of true duals over the y-pipe
Old Nov 5, 2003 | 04:04 PM
dnz28's Avatar
soooooooo is there any?
Old Nov 5, 2003 | 04:07 PM
BitCypher's Avatar
Good post! I have had the same question for quite some time.
One issue with most dual setups is ground clearance and noise reverb under the car. Other than that, I'm most interested in the power differences.
Old Nov 5, 2003 | 04:10 PM
97FormulaWS-6's Avatar
reverb can be eliminated if you don't dump the exhaust under the car... I have mine comming out the sides and have no reverb inside..
yes, the ground-clearence suffers...
What are the advantages... well, basically it just frees up the exhaust flow more than converging all the exhaust into a single pipe, althought most true-duals have some sort of cross-over with the x-pipe being the most common on f-bodies..(including mine)
I believe the only cat-back that will flow similar numbers is the 4" one (don't remember the name of the mfg, maybe someone else will chime in).
not to mention it HAS to be custom fabbed... I've heard of a bolt-on kit, but it was well over $600 and seeing it cost me a total of $150 to make mine.. $600 is a little crazy...
Old Nov 5, 2003 | 04:26 PM
FacelessZ's Avatar
4" cat-back made my mufflex
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
