Head expert in here
Old Nov 6, 2003 | 11:34 AM
DamianLT1's Avatar
Head expert in here
Any guess on how much HP this port job plus CC305 cam
should produce?
Valve Job 3 angle
Stage II porting
Valve 1.940" IN / 1.500" EX Manley Stainless
Springs 1.250" Double Installed
Seals- Umbrella
Lock & Retainers 7 degree Comp Cams
Milling .005"
Flow- 235 cfm IN / 180 CFM EX @ .500" lift
Old Nov 6, 2003 | 11:46 AM
FacelessZ's Avatar
no head expert here...but id venture a guess at 20-25+ hp
Old Nov 6, 2003 | 02:35 PM
pat97SS's Avatar
I would hope more than that. I would hope that the cam alone would make 20-25 HP.
Old Nov 6, 2003 | 02:42 PM
Ai's Avatar
Ai
In general, most peoples "stage 2" stuff peaks in the 25Xcfm range that I've tested on our bench. If you're lucky, 265-270 & rarely the usual 270+ claimed in real life.
Stock is around 210cfm... & you're running stock replacement parts in a head that flows about like an untouched LT4 casting. I'd hope for 350rwhp or so with an M6 car.
Old Nov 6, 2003 | 02:48 PM
DamianLT1's Avatar
That's what I'm hoping for with all my mods I just need to get tuned for the cam. Mail order for now, dyno is too much $$$. I'm not sure if dyno would be worth it for my mods.
Old Nov 6, 2003 | 04:26 PM
FacelessZ's Avatar
I was commenting on just the heads...like I said I'm no expert....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Dec 28, 2014 06:20 PM
