Oil Pan Gaskets
Old Nov 7, 2003 | 06:57 PM
c0rey's Avatar
Oil Pan Gaskets
hey i was wondering what i need to do to change the oil pan gaskets? do i have to lift the motor?
Old Nov 7, 2003 | 07:01 PM
suleb's Avatar
not knowing what tranny you have, remove y-pipe, loosen and lower trans pan, remove pan ensuring all crank balance throws are up in the block(to provide clearence for the front lip of the pan. 1-2 hours with a lift, no lift-have fun.
Old Nov 7, 2003 | 07:02 PM
c0rey's Avatar
i have the a4
Old Nov 7, 2003 | 07:06 PM
suleb's Avatar
take off the flexplate cover at the bottom of the trans, can't remember if you have to remove the starter, trucks you do. with the cover out of the way should be home free.
Old Nov 7, 2003 | 07:08 PM
c0rey's Avatar
damn sounds easy!!!! might have to do it
Old Nov 7, 2003 | 07:12 PM
OBE1 95Z28's Avatar
I like the Felpro gasket much better than the GM one. It provides better sealing surfaces, goes on dry (no RTV) and has molded in spacers to prevent over-tightening.
Old Nov 7, 2003 | 09:09 PM
c0rey's Avatar
thank u all so much
Old Nov 7, 2003 | 09:36 PM
c0rey's Avatar
what weight of oil should i use 10-30? i got 82k
Old Nov 7, 2003 | 10:42 PM
mvnatedog's Avatar
GM recommends 5w-30, and especially since you are in NB and your car is likely to be exposed to temps <0*, that's what I would go with.
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
