Hooking up PC to car?
Old Nov 7, 2003 | 12:55 AM
NewbieWar's Avatar
ok ive read a few times that people plug their lap tops up to their cars...
what kind of a cable do u need
where the heck does it plug into
what kind of software does it require
and how much does it all cost?
Old Nov 7, 2003 | 01:18 AM
WheelmanZ28's Avatar
Hey man,
U can get the cable itself at www.akmcables.com
They also give u the specs, parameters, and parts list of what u need to build the connector. Or if ur willing to shell out about $75, u can have one that is already built if ur not a plug builder.
The tuning plug actually plugs into the OB1 serial port connector, which u'll find above Driver's right knee, underneath most of the dash.
The software u can find at many places, like www.ls1speed.com for data logging
As for tuning software, their are a few choices like Tuner Cat, but LT1 EDIT is probably the most prominent and preferred.
Prices (close estimations):
Cable and connectors - $75-95
Data Logging software - $150-$250
LT1 EDIT - $150
Plus, the laptop of ur choice
Old Nov 7, 2003 | 04:59 AM
CheshireCat's Avatar
I agree with WheelmanZ28
I have a 94Z28 and bought my cable from www.akmcables.com. The cable costs $95. There are many programs you can use with this cable and your computer. I'm using FreeScan and it works great for reporting trouble codes and monitoring the status of your LT1. There are probably better programs out there, but FreeScan is a great starting point since it is free... It is best if your computer has a RS232 9pin serial port. Andrew at AKM cables was a pleasure to deal with and I had my cable 3 days after I ordered it. It worked perfectly and was easy to use. The connector is located below and to the right of the ignition switch and may be covered by a rectangular dust cover.
I hope this helps.
Old Nov 7, 2003 | 07:28 AM
chaotik169's Avatar
will this work with OBDII? a 97?
Old Nov 7, 2003 | 09:32 AM
anasazi's Avatar
no
mr28
Apr 20, 2016 05:44 PM
sdn1997rs
Dec 30, 2014 08:30 AM
Injuneer
Dec 15, 2014 09:36 AM
USAirman93
Nov 24, 2014 03:37 PM
mr28
Nov 23, 2014 11:11 AM
