Need help changing transmission fluid
Old Nov 6, 2003 | 09:26 PM
stang_killa94's Avatar
I want to change my transmission fluid myself but i was wondering if its hard? is it just like changing the engine oil? Where do i drain and fill the fluid from? Any help would be greatly appreicated. Thanks
Oh yeah and what type fluid is needed for my 94 z28 A4?
Old Nov 6, 2003 | 09:35 PM
95grandsport's Avatar
you can get under the car and remove the transmission pan. This will drain approx 1 gal of Dexron ATF. Please note you will need a trans pan gasket and filter kit.(see your dealer) This method is ok but will only change a fraction of your trans fliud. Other methods involve using specialized machines that will remove all of your fliud and replace it with new stuff. I work at a Chevy dealer and we use BG cleaning agents, I use this stuff on my "built" tranny with very good success. If you can spend $100 on it I reccomend it whole heartedly.
Old Nov 6, 2003 | 09:43 PM
ughh its harder than i thought........i want to change all of it not just part......i went to a jiffy lube and they said it was 80.00 do you think that includes all the parts you're talking about?
Old Nov 6, 2003 | 09:51 PM
Jiffy Lube SUCKS! Ask them if they are changing the filter or using a machine to flush out the old fluid. For $88 they are probably doing a flush which is good. Remeber filter=only 1 gal changed. Flush=all changed. I do not know if they are using chemical treating or not, but I only trust the BG stuff cause I use it every day and have seen nothing but good from it.
Old Nov 6, 2003 | 09:56 PM
ok cool thanks!
but if i were to go to a chevy dealer to get this done it would be around 100.00?
Old Nov 6, 2003 | 10:13 PM
at the one I work at it is, but I live in FL. You live in Chicago so it'll probably set you back a little more. By the way, how's the weather?
Old Nov 6, 2003 | 10:26 PM
badazzcamaro97's Avatar
As far as trans fluid I use B&M, but a friend of mine really likes the Royal Purple
Old Nov 6, 2003 | 10:37 PM
its been raining for the past 4 days but today was REAL sunny but cold and tomorrow is gonna be the same and on sunday mostly sunny and a little warmer. Why?
PCLZ28
Dec 24, 2015 05:19 PM
jmadoll
May 27, 2015 07:13 PM
warmeck
Mar 16, 2015 07:02 AM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
