Specs on the GM 8xx cam?
Old Nov 4, 2003 | 07:00 PM
kgkern01's Avatar
Just wondering what the specs are on the GM 8xx (not sure of exact #, maybe 847?) as far as duration, lift, and LSA?
Old Nov 4, 2003 | 07:24 PM
LPE Z convt's Avatar
234/242@.50 dur and 575/595 lift with a 1.6 roller rocker
Old Nov 4, 2003 | 10:49 PM
atljar's Avatar
LPE nailed it, 112lsa, and the thing is BAD!
Here is the full cam card (crane version but exact same thing)
http://dab7.cranecams.com/SpecCard/D...1=Display+Card
Old Nov 5, 2003 | 01:13 PM
kgkern01's Avatar
Max RPM at 6500, Valve float at 6800 RPM? I thought people were taking the CC306 to that range without any problems with the proper valvetrain parts? Shouldn't this cam handle that as well? Would a rev-kit help valve float? What is the LSA, or can you get it varied? Is it avail in 112?
Old Nov 5, 2003 | 02:06 PM
atljar's Avatar
It is on a 112, and you can get it varried just like any cam.
Valve float is based on their spring requirements they listed. Bigger spring and they wont float. Min/Max operating range is just a "guess" with their listed components. You can see a dyno chart on my web page with stock heads to give you a good idea of its powerband.
Old Nov 5, 2003 | 02:38 PM
Grease's Avatar
Just so you know, I use CC987 springs with that cam and I spin up to 6800rpm with no valve float. If you use the right springs then you won't have to worry about valve float.
Old Nov 5, 2003 | 02:42 PM
got_hp?'s Avatar
my GM847 just arrived last nite............just waiting for my lifters to show up, and i cant wait to have this thing put in!
er....then its new clutch time.
Fastbird93
Apr 9, 2016 07:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Nov 20, 2014 06:03 PM
