How high to jack the motor for the oil pan...
Old Nov 5, 2003 | 10:07 PM
94_Camaro_LT-1's Avatar
Question How high to jack the motor for the oil pan...
Im gonna be attempting this tomorrow afternoon and would like to know about how high its gotta be jacked up...I got the stock pan loosened and waiting to be jacked to remove it and put my new Canton pan and pickup on Thanks in advance
Old Nov 5, 2003 | 10:27 PM
QCKZ28's Avatar
be sure to remove both motor mount bolts. you have to jack the motor up until the tranny almost hits the firewall. and dont forget to unbolt your tranny mount.
Jesse
Old Nov 5, 2003 | 10:55 PM
Thanks guess I just keep on jackin till can't go no more. Where should I jack it from? the bellhousing??
Old Nov 5, 2003 | 11:47 PM
QCKZ28's Avatar
i know this is a major NO-NO, but i used the crank snout
i was in a hurry, and it was easy, and it worked. if i had it to do over again i would have found a better place, because now i have a very small rear main oil leak that wasnt there before my heads/cam. oh well live and learn i guess.
jesse
Old Nov 6, 2003 | 02:20 AM
RUFFIDLNZ's Avatar
Do you have access to a motor hoist? If so hook a chain somewhere on the top of the motor and raise it that way. There is no way I would jack up the motor using the crank snout If you get lucky doing it great but if something breaks your going to be doing a lot more work than just changing oil pans I know you probably already know this but dont forget to tack weld your oil pump pickup to the oil pump so your for sure it wont fall off in the oil pan.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
squarehead
Nov 21, 2014 08:02 PM
